Need Replacement Battery
#124807
12/14/14 12:10 AM
LRJ
Posts: 598 |
The battery in my '07 has died. It probably was the original battery. Any hearty recommendations for a replacement brand/model? I tried searching for information on this site, here, but haven't had any luck finding recent recommendations.
Thanks for any help.
LRJ Take time to play. / '07 xt225/'00 TT-R250 Tusk Bark Busters & Hand Guards / 3KCustoms Aluminum Rack
Re: Need Replacement Battery
[Re: LRJ]
#124808
12/14/14 12:42 AM
patuca
Posts: 584 |
The standard Yamaha recommendation is a Yuasa ytz7s, which is a high quality battery which I recommend. They last for many years and are trouble free. http://www.motorcycleinnovations.ca/YUASA_YTZ7S_p/ytz7s.htmI would go for this before anything. patuca
[Re: patuca]
#124809
12/14/14 01:34 AM
Posts: 4,163 |
Agreed. Yuasa makes good batteries. Get a battery tender while you're at it.
[Re: LRJ]
#124817
12/14/14 06:03 AM
LRJ
Posts: 598 |
Thank you, gentlemen. They appear to be more expensive than some alternatives, but "trouble free" and "many years" sounds very good.
[Re: LRJ]
#124819
12/14/14 06:52 AM
I have the original batteries in 3 bikes: 2005/2005/2006. And they've seen massive vibration and banging around on the trails; something that doesn't help battery life.
The secret is Harbor Freight's little $4.99 float-chargers, which I constantly have on the bikes when they're garaged.
[Re: LRJ]
#124822
12/14/14 03:31 PM
Tye
Posts: 36 |
Ever start es5lbs at Walmart $50 works well for me
Go jays go
[Re: Tye]
#124823
12/14/14 03:46 PM
deodom
Posts: 1,175 |
Battery Mart AGM batteries have worked fine for me, at about $55, delivered by FedEx.
'07 XT225/Z1 mod/short snorkle/130-42.5-3 turns/Load Lord Rack/Vibrinator bar end weights/Padded Seat/kickstarter
[Re: LRJ]
#124825
12/14/14 04:20 PM
Posts: 2,114 |
Yuasa, every time. Trouble free & good CCA.
[Re: LRJ]
#124834
12/15/14 03:08 PM
Posts: 6,621 |
Yuasa makes a good battery. I've had these in both bikes for years and never used a float charger. One winter season they sat in storage with low temps at -24F for periods of 1-2 days. In the Spring both bikes started. Amazing. Obviously these batteries (on our bikes) take their fair share of mechanical abuse. Odyssey also makes a premium battery but I'm not sure if they have an XT version. Yuasa is good and so are others. Truth be known, Walmart would be the last place I'd shop for a battery.
If you can get the weight of a good battery like a Yuasa and compare that to other brands you might be considering, it will help tell you how much lead is in the plates. More lead will help a battery last a bit longer and may increase its tolerance for mechanical abuse. Installing a headlight "off" switch will help deliver more cranking amps for those models that leave the headlight on during cranking.
Also keep in mind the XT doesn't take its ignition power from the battery. That system runs via a magneto. Terrain permitting, you can always pop start (and run) an XT225 with a dead battery. A small comfort, perhaps, knowing a dead battery isn't a ride show stopper.
Good luck shopping!
#126606
05/15/15 03:34 AM
XTmonster
Posts: 114 |
"Also keep in mind the XT doesn't take its ignition power from the battery. That system runs via a magneto. Terrain permitting, you can always pop start (and run) an XT225 with a dead battery. A small comfort, perhaps, knowing a dead battery isn't a ride show stopper."
Wow I had no clue, good to know. Thanks for that info. I would hate to get stuck in the desert and cant pop start it!
bbbbb
Members6,016
